- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Orbi and MacBook Pro
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi Wifi 6 router (RBR850) frequently disconnects with the new MacBookPro. Interestingly, a friend of mine has the same combination and he is experiencing the same problem. It's frustrating that $600 router doesn't work and warranty on the product is very bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Orbi and MacBook Pro
What model Mac do you have?
What OSX version are you using?
What distance is the mac book from the RBR?
Is there a RBS850 online as well?
Does changing from CTS 64 to 2347 help any Under Advanced Tab/Advanced Settings/Wireless Settings
@RAPA wrote:Orbi Wifi 6 router (RBR850) frequently disconnects with the new MacBookPro. Interestingly, a friend of mine has the same combination and he is experiencing the same problem. It's frustrating that $600 router doesn't work and warranty on the product is very bad.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi firmware version is V3.2.16.6
ISP os Comcast.
Modem model is ARRIS Group, Inc. TG3482G.
MacBook Pro. model is 2.0GHz Quad-Core Processor with Turbo Boost up to 3.8GHz, 512GB Storage, Touch Bar and Touch ID. Bought July 2020.
Location doesn't seem to matter - I've kept the modem at the line of sight, same floor different room and different floor. Same issue
Channel is set to Auto.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What mode is your Arris modem working in Router or Modem only? If router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
What happens if you change CTS values from 64 to 2347 under Advanced Tab/Advanced Settings/Wireless Settings or disable AX mode on the RBR...
- Mark as New
- Bookmark
- Subscribe
- Permalink
All radio/wiifi on the modem is disabled. The cable modem/router is set to run on Bridge mode.
Where do i set the following?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
On the RBRs web page. Follow the path that I mentioned to find that setting.
AX mode is on the Basic TAB/Wireless settings page on RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"What happens if you change CTS values from 64 to 2347 under Advanced Tab/Advanced Settings/Wireless Settings or disable AX mode on the RBR..."
What does this do? Should i change the CTS values both 2.4 GHZ and 5GHZ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, what does disabling Ax feature do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes.
AX is a wireless mode, like Wireless AC, N, G and so on. Sets connection rates for those devices that support those modes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I disabled Ax for now. As you may know, MacBookPro doesn't support Wifi 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya I know. Mine doesn't either, however with AX mode enabled, devices should remain connected.
Please make contact with NG support about what your see with and with out AX mode enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Keeping my fingers crossed. Thank you for your help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes.
