Orbi WiFi 7 RBE973
Reply
Network Round Trip Time Spikes ever few Seconds on Orbi ax4200 RBR750
Zipsy
When pinging google on command prompt the ping rises occasionally, but when playing games like valorant the network round trip time or ping spikes up every like 2 seconds.
Message 1 of 60
Accepted Solutions
Zipsy
Re: Network Round Trip Time Spikes ever few Seconds on Orbi ax4200 RBR750
Just finished troubleshooting and experimenting with everything I could. The thing that was causing it was actually the power extenders! When changing the router plug into an actual outlet in the wall the wifi was great. It was lightning fast. At least I know now.
Message 52 of 60
All Replies
Guru
What are the ping results if you connect a wired PC to the ISP modem/ONT and use the free trial ping plotter program from pingplotter.com with out the RBR?
Message 2 of 60
Zipsy
When connecting to the modem everything is fine. No ping spikes or anything and I have also contacted my internet provider to see if anything was wrong on their end. Nothing. V3.2.16.6_1.4.4 is the firmware
Message 3 of 60
mschoenf
I am Also having this same behavior while playing wow, with firmware 3.2.16.6
Message 4 of 60
Guru
Message 5 of 60
Zipsy
I also talked over the phone with someone at netgear and they didn't seem to have an answer for it.
Message 6 of 60
Guru
I would probably return the 7 series and try a 8 series to see if the problem follows.
Message 7 of 60
Zipsy
It's best if I can just fix it on the router itself since returning it will be hard with everything that is happening right now.
Message 8 of 60
Guru
Message 9 of 60
Zipsy
how do I find that
Message 10 of 60
Guru
Is there another box unit that the RBRs WAN port is connected too or is this to wall jack? If there is another unit, then look at the units stick, in back or under, to see a mfr and model# of the modem or ONT unit.
Message 11 of 60
Zipsy
If the mfr is manufacturer then it's netgear and the model is CM400. I also have have access to the settings of my motem but not sure if I should change anything in there.
Message 12 of 60
Guru
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
Message 13 of 60
Zipsy
I did that just yesterday and everything was fine on their end.
Message 14 of 60
Guru
Can you attached a screen shot of ping plot and a capture of the ping command ran from a wired PC thats connected to the RBR. I would disconnect ALL other devices from the RBR temporarily. Change the SSID name temporarily so that wireless devices won't connect. Then run these two tests with you PC connected to the RBR. Test with and with out the game running.
Message 15 of 60
Zipsy
Sorry I am not able to provide a screenshot anytime too soon. But I ahve tried this before and the ping still spikes. Its just that overall ping compared to the wireless is like 2 ms faster.
Message 16 of 60
Zipsy
Here is the chart but in game the network round trip time spikes in sort of a pyramid shape. It seems that the real effects of this are apparent in game when it spikes. The first one is an image of the ping when connected to the router.
This is an image of the ping when connected to a satellite
The ping on the satellite is better than when the router is. The satellite is right next to my laptop so distance shouldn't be an issue.
Message 17 of 60
Guru
Here is my ping to Google using a wired PC connected to a ASUS wireless bridge connected to my Orbi AX system:
Message 18 of 60
Zipsy
Yours looks fine. Mine is weird.
Message 19 of 60
Guru
Are ping times the same if you ping the routers LAN IP address?
Message 20 of 60
Zipsy
The ping spikes are still there it's just the overall ping is lower.
Message 21 of 60
Guru
Do same test with RBS disabled and if you can with the RBR disconnected from the modem and all other devices disconnected from the RBR. IF you still see some spikes, I would presume there maybe some thin in 7 series FW that differs from 8 series FW and something that NG should look into.
Message 22 of 60
Guru
Message 23 of 60
Zipsy
Still spiking
Message 24 of 60
Zipsy
When connected only to the router the spikes are even worse and last longer.
Message 25 of 60
Top Contributors
Discussion stats
  • 59 replies
  • 5322 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
