Orbi WiFi 7 RBE973
Reply
New - RBRE960 / RBSE960 Firmware Version 7.2.6.31 Released
Guru
Enhancements: 03/22/2024
(For all regions except Europe)
  • Improves the stability of WiFi device connections during roaming
  • This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security
  • Unforeseen issues with NG and the EU region, NG had to pull v7.x FW version from being pushed to 960 series users in the EU region. Manual updating is not supported as well. Seems there maybe some wifi policy that has to be figured out between NG and the EU region. We've asked about this and for now, it's a work in progress and NG is aware of it. So if your in the EU region, v6.x version of FW is all that is currently supported for the EU region users. We no further information on when this will be resolved.
Download Link:
https://www.netgear.com/support/product/rbke962#download
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documenta...
NOTE: Update the RBS first, then the RBR lastly. I recommend doing a full on factory reset after the FW loads, system is back to ready and a power OFF for 1 minute then back ON has been performed. Use a wired PC and web browser for this. Load the FW on to each RBS web page using the RBS web page, not thru the RBRs web page. Then load the FW lastly on the RBRs web page. Walk thru the setup wizard. You can manually setup the system as well for those who are more experienced with this.
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelli...
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co...
I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS.
A factory reset maybe needed if problems are encountered:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
The best advise we can give people is to start a new config, power on one RBS and wait for some SOLID light or most often blue or magenta. And then add the RBS WIRELESSLY via the WebUI. Power off the RBS. Then rinse and repeat with any additional RBS(s). Pair RBS one at a time even if you have more than one. For ethernet connected RBS, after things come up wirelessly, you can move to wired backhaul but don't start with wired backhaul for those RBS that are ethernet connected. Wirelessly connect and sync RBS first before ethernet connecting RBS.
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
NOTE: The Disable Auto Update feature only prevents ANY new FW from being installed if available. This does NOT prevent the system from checking NG services to see if new FW is available. If new FW is available, this will be displayed as a notification to the user on the RBRs web page only. It will be up to the user to upgrade FW or not.
This article applies to:
Let us know how it works for you in this thread...
Message 1 of 132
Accepted Solutions
donawalt
Prodigy
Re: New - RBRE960 / RBSE960 Firmware Version 7.2.6.31 Released
I have noticed issues that only seem to crop up after days of running - as few as 3-4 days, as many as 22 days. They are router or satellite restarts, memory growth in satellites to the point of causing a reboot and disconnect of all devices. I have seen WiFi disconnect and stop working until the router was rebooted. Have seen IPv6 stop working until it was re-enabled (likely a Comcast-NG interaction issue). I have seen satellites lose their backhaul connection with the router.
I believe at least the memory creep issues are related to using 2 satellites on Ethernet backhaul, just a guess. It could also be related to higher speed networks, mine is a 2G/200MB service. Maybe it's a combination of different factors that make the perfect storm that problems can appear? The % of Netgear customers with 2G and multiple Ethernet-wired backhaul satellites is small, I suspect. Plus, if there are some bugs that pop up after a number of days of running, NG has said that this kind of testing is very hard for them to do.
I just went back to v.21 to see how it runs. If v.31 is working well, great - if not, some caution could be warranted to try V.21 before spending lots of time trying to find a problem.
Message 104 of 132
All Replies
spewak
Luminary
Updated. Will see how it goes.
Thanks Furry.
Message 2 of 132
donawalt
Prodigy
I updated tonight. All good so far.
Message 3 of 132
donawalt
Prodigy
I have been doing some testing and analysis with the 7.2.6.31 FW update on a RBR/RBS 960 network. It's chronological update through the day.
Here is my update from today, some interesting data to share on my 7.2.6.31 testing. Note - IPv6 IS ENABLED (I have had trouble with that, Comcast ISP, in the past)
1) This morning, the 3rd floor RBS was showing HC of blank. It started last night late. By the time I went to bed, it had disconnected any devices connected to it.
2) At the time when hop count went from 1 to blank, meaning devices would no longer connect to it via WiFi - CPU shot up to 26%. By this morning CPU was 29%.
3) With IPv6 enabled, the Router memory climbed to 580MB. Without IPv6 it's normally 360-390MB. For the last 2+ hours it has stayed up/down in the 576-580MB range.
4) I power cycled the 3rd floor RBS two hours ago, everything looks stable now. Devices are connected to the 3rd floor RBS again.
5) Here's a snapshot of each at this time, you can see when the one RBS went from hop count 1 to blank - and its CPU shot up:
Router:
Time: 03/24/2024, 08:29:30 CPU %: 11.81% Memory Usage: 580 MB/818 MB Uptime: 0 days 14:02:39
Time: 03/24/2024, 08:39:28 CPU %: 11.81% Memory Usage: 580 MB/818 MB Uptime: 0 days 14:12:37
Time: 03/24/2024, 08:49:27 CPU %: 11.80% Memory Usage: 576 MB/818 MB Uptime: 0 days 14:22:36
Time: 03/24/2024, 08:59:25 CPU %: 11.79% Memory Usage: 577 MB/818 MB Uptime: 0 days 14:32:34
Time: 03/24/2024, 09:09:23 CPU %: 11.78% Memory Usage: 577 MB/818 MB Uptime: 0 days 14:42:32
Time: 03/24/2024, 09:19:22 CPU %: 11.75% Memory Usage: 579 MB/818 MB Uptime: 0 days 14:52:31
RBS that just went to HC blank last night:
Time: 03/24/2024, 06:48:09 CPU %: 29.46% Memory Usage: 394 MB/812 MB Uptime: 0 days 12:8:40 HopCount:
Time: 03/24/2024, 06:58:11 CPU %: 29.49% Memory Usage: 377 MB/812 MB Uptime: 0 days 12:18:42 HopCount:
Time: 03/24/2024, 07:08:13 CPU %: 29.51% Memory Usage: 377 MB/812 MB Uptime: 0 days 12:28:44 HopCount:
Time: 03/24/2024, 07:18:15 CPU %: 29.52% Memory Usage: 378 MB/812 MB Uptime: 0 days 12:38:46 HopCount:
Time: 03/24/2024, 07:28:17 CPU %: 29.54% Memory Usage: 378 MB/812 MB Uptime: 0 days 12:48:48 HopCount:
Time: 03/24/2024, 07:38:19 CPU %: 21.8% Memory Usage: 324 MB/812 MB Uptime: 0 days 0:2:19 HopCount:
Time: 03/24/2024, 07:48:21 CPU %: 14.4% Memory Usage: 343 MB/812 MB Uptime: 0 days 0:12:21 HopCount: 1
Time: 03/24/2024, 07:58:23 CPU %: 11.32% Memory Usage: 342 MB/812 MB Uptime: 0 days 0:22:23 HopCount: 1
Time: 03/24/2024, 08:08:25 CPU %: 10.15% Memory Usage: 343 MB/812 MB Uptime: 0 days 0:32:25 HopCount: 1
Time: 03/24/2024, 08:18:27 CPU %: 9.46% Memory Usage: 344 MB/812 MB Uptime: 0 days 0:42:27 HopCount: 1
Time: 03/24/2024, 08:28:29 CPU %: 9.05% Memory Usage: 344 MB/812 MB Uptime: 0 days 0:52:29 HopCount: 1
Time: 03/24/2024, 08:38:31 CPU %: 8.8% Memory Usage: 344 MB/812 MB Uptime: 0 days 1:2:31 HopCount: 1
Time: 03/24/2024, 08:48:33 CPU %: 8.63% Memory Usage: 344 MB/812 MB Uptime: 0 days 1:12:33 HopCount: 1
Time: 03/24/2024, 08:58:35 CPU %: 8.49% Memory Usage: 345 MB/812 MB Uptime: 0 days 1:22:35 HopCount: 1
Time: 03/24/2024, 09:08:37 CPU %: 8.4% Memory Usage: 345 MB/812 MB Uptime: 0 days 1:32:37 HopCount: 1
Time: 03/24/2024, 09:18:39 CPU %: 8.31% Memory Usage: 345 MB/812 MB Uptime: 0 days 1:42:39 HopCount: 1
The other RBS:
Time: 03/24/2024, 08:23:59 CPU %: 9.76% Memory Usage: 369 MB/812 MB Uptime: 0 days 13:51:4 HopCount: 1
Time: 03/24/2024, 08:34:01 CPU %: 9.75% Memory Usage: 369 MB/812 MB Uptime: 0 days 14:1:6 HopCount: 1
Time: 03/24/2024, 08:44:03 CPU %: 9.74% Memory Usage: 369 MB/812 MB Uptime: 0 days 14:11:8 HopCount: 1
Time: 03/24/2024, 08:54:05 CPU %: 9.72% Memory Usage: 370 MB/812 MB Uptime: 0 days 14:21:10 HopCount: 1
Time: 03/24/2024, 09:04:07 CPU %: 9.71% Memory Usage: 370 MB/812 MB Uptime: 0 days 14:31:12 HopCount: 1
Time: 03/24/2024, 09:14:09 CPU %: 9.7% Memory Usage: 370 MB/812 MB Uptime: 0 days 14:41:14 HopCount: 1
6) Funny how both the last two times after a power cycle of everything, within a day I had an RBS (different one) fail with hop count blank. I then went 9-10 days with no problems after that. Last time it was with IPv6 disabled, this time IPv6 is enabled.
7) I noticed one other version change on the routers debug page, from the FW upgrade to 7.2.6.31. “Seal“, whatever that is, went from 2.15.49–0 to 2.15.50–0. I wonder what that is?
😎 OK, I just noticed that IPv6 has failed. I am going to disable it and power cycle everything again. Things seem to get really unstable with IPv6 enabled here.
9) There is always so much drama on power cycles. It's like it can't handle 2 RBSs coming up near the same time. I always bring one up, wait for the blue LED, then power up the other. This time the 1st floor RBS came up Blue, as did the other; but 20 minutes in the stats showed the 1st floor RBS had hop count blank (it never did show hop count of 1), and the router did a big hop in memory from 353 to 403. The other RBS was HC 1 in 7 minutes. So I power cycled the 1st floor RBS again, the first report at 6 minutes showed all good and HC 1.
10) Ugh - 1st Floor RBS just went Hop count blank at 16 minutes powered on.
11) This time I powered off the RBS and RBR, waited 2 minutes, brought up the RBR, then waited TEN minutes for things to settle down. I just powered up the RBS. IPv6 has now been disabled. But Hop count is STILL blank - and nothing connecting to the satellite.
12) I tried power cycling again, and it never got out of hop count blank. So this time I powered off the other RBS, took the offending RBS down next to the router, let it sync wirelessly, then brought it up and powered it on. Hop count is 1 so far!
My suspicions: there are bugs with:
- Ethernet backhaul. I have had similar issues to this with the Orbi 850 series too, as well as with 7.2.6.21 and 7.2.6.31 Firmware. Another user has had them on his network. WiFi seems more stable.
- Power cycling the network seems very hit or miss. I frequently have to power cycle on of the RBS AGAIN.
- Hop Count turns off for no apparent reason - then nothing connects via WiFi. Note, anything connected direct continues to work, so the backhaul is fine (and it is reported as fine on the router admin web page)
- Last night router was in a steady memory creep - like there is a memory leak.
Message 4 of 132
Guru
Thank you @donawalt Great information.
Seems like IPv6 is being problematic, again. 🙄
Ya, we need to get some info on Hop Count behaviors. Seems like when RBS are ethernet connected, something stops working after period of time and seems to stop the RBS from working properly.
I recommend that you open up a NG support ticket with your 960 series and put all this in a support ticket to help with letting NG know about this. Seems like this should not be happening and something in FW needs to be checked into.
Message 5 of 132
donawalt
Prodigy
will do!
Message 6 of 132
Guru
And of posterity, what is the brand and model# of the ISP modem your currently using with the RBR960 and ISP your with?
Message 7 of 132
donawalt
Prodigy
ISP is Comcast, 2000/200 plan.
Modem is Netgear CM3000.
Message 8 of 132
owlyn
Luminary
Updated my two satellites and then the router. No problems. Found that it changed my IPv6 DNS settings to get from the ISP rather than the ones I manually entered previously. Changed those back to the manual settings (to what the ISP uses!) , and discovered IPv6 DNS doesn’t work with Armor Web Protection turned on. Turned it off and no problems.
Message 9 of 132
donawalt
Prodigy
Thanks for the update @owlyn  !! So you are back to using Manual IPv6 settings again? If I could ask, if you go to 192.168.1.1/debug.htm (or whatever your router IP address is), how much memory is it using, probably out of 818MB available? And who is your ISP?
Message 10 of 132
owlyn
Luminary
Wow! CPU load is only 13.09% Comcast 1200/35.
Message 11 of 132
Guru
Brand and model of modem used for posterity please?
Message 12 of 132
owlyn
Luminary
Oops. Memory usage is 394/818
Message 13 of 132
owlyn
Luminary
Netgear, but it is a beta under NDA, but is similar to the 3000.
Message 14 of 132
donawalt
Prodigy
394MB is good. Mine gets into the low 600's with IPv6 enabled on Comcast. I wonder if I should try manually adding the settings...you just typed in exactly what Comcast set up for you?
Message 15 of 132
Guru
OHHHHHH. k. I think I know. 😉
Gratzie.
Message 16 of 132
donawalt
Prodigy
Me too!!
Message 17 of 132
owlyn
Luminary
Yes it is what Comcast published for the DNS entries.
Message 18 of 132
Guru
And how is your IPv6 configured on your RBR? Auto, DHCP? Static?
Anything you can pass to @donawalt would be great.
Thank you kindly.
Message 19 of 132
donawalt
Prodigy
@owlyn so you selected "Use these DNS servers" and filled in Comcast's IPv6 DNS server addresses, got it. Was the Router's IP address on the WAN assigned I assume? And did you do "Auto config" for LAN Setup? And in the top right, did you select Auto Config, or DHCP?
Thanks for your info!
Message 20 of 132
owlyn
Luminary
The only thing that was wrong was the DNS selection. The manual addresses were in there from previously, but the wrong selection was made.
Message 21 of 132
donawalt
Prodigy
@owlyn thanks for the reply....so originally you selected "Static" and added everything in - LAN IP, WAN IP, DNS servers, based on what Comcast set it as when prior you selected "Auto detect" or "DHCP". If I have that correct, thanks for the info!
Message 22 of 132
owlyn
Luminary
I don’t remember how I did it originally, but it is set for DHCP and autoconnect. Except for the DNS as noted previously.
Message 23 of 132
bullm00n
Virtuoso
I have not had time to do this update yet and am slightly hesitant as it took forever to get stable here with all the Xfinity upgrades/disruptions last year and the funky previous version of firmware that hated my Comcast modem (or the modem hated it!).
But I will give a go as soon as I can - especially given the other Xfinity comments. I have had no issues with IPV6 with the current release V7.2.6.21_5.0.20 with the xFi gateway, so will be curious to see how it goes with this update.
Message 24 of 132
donawalt
Prodigy
Here's my latest status since my post (above), on 3-24.
I am 3 hours shy of 11 days up now. Things have gone fine since that last post on 3-24. I still have IPv6, and I have not rebooted or power cycled the modem, router, or 2 satellites during this time. I have not had any of the hop count going blank issue when devices can no longer connect to a satellite via wifi, or restart issues, or memory creep issues.
Router - 10.15% CPU, 392MB memory.
Satellite 3rd floor: 7.21%, 362MB, Hop Count 1
Satellite 1st floor: 6.3%, 358MB, Hop Count 1
I am not sure how long I will let this run to see if the stability continues. I know if I turn IPv6 on, I will have trouble in 1-3 days - I have in the past. I'll try it again at some point...
PS - I have a support ticket in on the problems I experienced in the 3-24 post above. No news yet, although they  have referred it to Engineering with the LAN captures I passed on from the router and satellites.
Message 25 of 132
Top Contributors
Discussion stats
  • 131 replies
  • 4998 views
  • 61 kudos
  • 11 in conversation
Announcements
Orbi 770 Series
