Orbi WiFi 7 RBE973
Reply
No internet through Orbi when modem set to bridge mode.
CreeksongOrbi
Modem:  Teltonika RUTX11 (AT&T)
Orbi Mesh WiFi 6 System - AX4200  (RBK752)
Internet accessible through modem, and through Orbi when modem not set to bridge. But this configuration produces noticeable performance issues (double NAT?).
Have placed RUTX11 in bridge mode, rebooted with Orbi connected -- Orbi connects to modem, but no internet. Connecting directly to modem (without Orbi) confirms modem does have internet access.
RUTX11 in bridge mode can operate without specified MAC address (accepts "first inline') or with specified MAC -- have tried both settings; can connect to internet without Orbi, but cannot connect to internet through Orbi, either with or without MAC specified.
Since Orbi was originally installed with modem not set to bridge, do I need to factory reset Orbi in order for it to work properly with new modem setting?  or is there something else I'm missing?
Message 1 of 15
CrimpOn
Guru
Re: No internet through Orbi when modem set to bridge mode.
The Orbi is in Router mode, correct?
Message 2 of 15
CrimpOn
Guru
What sort of performance issues?  Double NAT seriously interferes with specific applications, but is invisible for 'ordinary web use' (email, web browsing, streaming video, Zoom meetings, etc.)
Message 3 of 15
CreeksongOrbi
Orbi is in router mode.
Web browsing noticeably compromised for certain sites -- pages slow to load, certain applications fail.  Noticeable difference with and without connection through Orbi.
Message 4 of 15
Guru
After setting Bridge mode on the modem and applying that change, power OFF the modem and RBR for 1 minute then back ON with the modem first then RBR about 1 minute later.
Message 5 of 15
CrimpOn
Guru
I cannot find an explanation of how Bridge mode is different from Passthrough mode.
https://wiki.teltonika-networks.com/view/RUTX11_WAN
Message 6 of 15
CreeksongOrbi
Set modem to bridge mode. Confirmed internet access via direct ethernet connection to modem.
Powered off modem and Orbi.
Powered on modem -- waited 3 minutes for it to reboot.
Powered on Orbi -- waited for it to reboot.
No internet.
(Have done this 3-4 times now over the past several days, same result.)
Message 7 of 15
CreeksongOrbi
ISP (AT&T Reseller) says "Passthrough" requires full factory reset to undo (meaning physical access to the modem, which is mounted at 3-story peak); "Bridge" can be undone via ethernet access to modem.
I've not been able to confirm that in any Teltonika documentation -- nor have I found any other explanation of the difference.
Message 8 of 15
Guru
I would contact your ISP and have them help you with this. There maybe some user account or PPPoE account information needed on the RBR to make it work when the ISP modem is in bridge mode.
Message 9 of 15
CreeksongOrbi
Already contacted ISP -- should work as configured.  I'm stumped.
Only other option I see is to put Orbi itself into bridge mode; loss of some Orbi functionality, but it might improve performance.
Message 10 of 15
Guru
AP mode I presume...yes for now...Something on the RBR doesn't like it when the ISP modem is in bridge mode.
Or use the DMZ or IP pass thru on the modem with the RBR in router mode. I think AP mode will be best.
Message 11 of 15
CreeksongOrbi
Thanks very much -- have switched Orbi to AP mode, connection is already working better; we'll see how it holds up.
Appreciate the help!
Message 12 of 15
Guru
Message 13 of 15
CreeksongOrbi
Got it - thanks!
Message 14 of 15
Guru
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 3708 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
