Orbi WiFi 7 RBE973
Reply
ORBI 960 no 2.4GHZ internet.
ktd2104
I have a system of 3 Satellites and 1 router of ORBI 960, FW: V6.0.3.85_3.1.15. I tried to turn on the IOT network with 2.4ghz only. The system broadcast the SSID, and I can connect to it, however, when I run speed test, it gave me a ping of 2562 (crazy high ping) and about 0.5 mbps in speed. This is ridiculously low. I can not connect any of my smart devices to it including:
-Eightsleep Mattress
-20 brilliant smart home controls
-All the google nest hub, mini, smart home devices,
-6 Arlo cameras
-6 Wyze v3 cameras
-MyQ garage opener.
I tried to factory reset, even swap out for 3 set of new router and Satellites, set CTS/RTS Threshold to 500, uncheck the box Enable 20/40 MHz Coexistence and manually set the channel to 1 6 and 11, NON OF THEM work in any combinations.
Please help me!
Message 1 of 6
Guru
Re: ORBI 960 no 2.4GHZ internet.
If you turn OFF the RBS, does the IoT network with with the RBR alone?
Does the devices connect if you set 2.4 and 5Ghz enabled on the IoT network?
Message 2 of 6
ktd2104
=> it's the Xfinity Gateway Gen 3
=> There is no 2.4Ghz internet in general, not only for the IOT. I put 2.4Ghz only for the IOT to test, and it does not have any internet. The main internet and guest internet work perfectly with 5.0Ghz, but still no 2.4Ghz, all devices require 2.4Ghz can not connect to any of the SSID.
When I first set up with only 1 RBR, No RBS, it has 2.4Ghz, however, it's at 0.5-1.0 Mbps, it's almost nothing.
=> When I set 2.4Ghz and 5Ghz combine then IOT just like regular SSID and Guest wifi, it works only with 5.0 devices, not 2.4 devices => meaning still no 2.4 Ghz broadcasting.
Message 3 of 6
Guru
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
If after turning off any WIFI radios on the ISP modem and powering OFF the Orbi system for 1 minute then back on and doing a factory reset on the RBR and setup from scratch, does not bring back 2.4Ghz connectivity, you'll need to contact NG support and open a support ticket: https://my.netgear.com/support/contact.aspx
Message 4 of 6
ktd2104
Yes I already did all the above, and contacted Orbi. No solution. They have been escalated to engineers level, but I never hear back.
Message 5 of 6
Guru
Keep in contact with NG.
@Blanca_O @KevinLiT
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1682 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
