Orbi WiFi 7 RBE973
Reply
ORBI AX Guest Network not broadcasting on Satellites
dcraig
Guide
I was hoping the latest firmware would fix the problem, but it hasn't.  When I turn on the Guest network functionality, the SSID for the Guest network is not being broadcast by the Satellites.  I can see and connect to the Guest network when in range of the Router (RBR850), but when I move out of range of the Router and into the range of one of the Satellites (RBS850), my device can no longer see or attach to the Guest network.  I know this is the case because one of my Satellites is in a separate building which is wired directly back to the Router and is completely out of wireless range to the Router itself.
I am running on the latest firmware V3.2.15.25 for all devices.
I have (1) RBR850 in Router mode with (2) RBS850 Satellites using wired backhaul.
Also curious why there in no reference to the Guest network when I log into the web GUI for the Satellites.  There are references to the Secure side of my network, but no reference to the Guest network.  See screenshot attached.
Message 1 of 9
Accepted Solutions
dcraig
Guide
Re: ORBI AX Guest Network not broadcasting on Satellites
I found the problem was being created by a Netgear GS724Tv4 24-port managed switch.  Taking that out of the mix, and placing a Netgear GS108 switch on each end, and the RBR and RBS connected to the switches, they connect up properly and the Guest network functions as designed.  Luckily I had an extra GS108 to try.  It was the GS724Tv4 24-port managed switch that was causing the problem, even though I had previously disabled all IGMP protocols and green features.
@FURRYe38 wrote:
What mfr and model # switches do you have? Mine are D-Link and HP and mine work here when ethernet connected.
@dcraig wrote:
I found my problem was due to having switches betweent the hardwired Router and Sats.  Once I removed the switches and had the Sats connected DIRECTLY to the Router via wired backhaul, the problem cleared up.  Now the SATS are broadcasting the Guest network and there is interenet connectivity on it.
Message 8 of 9
All Replies
Guru
Has a factory reset been performed on the RBR and RBS and setup from scratch?
Message 2 of 9
dcraig
Guide
Not recently.  Does this typically solve the problem?  I hate to go through all the setup again and have it make no difference.
This has been a problem since day one, and  was hoping that future firmware updates would solve the problem.  But it hasn't thus far.
When I first noticed this problem, I was running in AP mode.  Then I factory reset everything and set up in Router mode.  But the problem still existed.  Three firmware updates later the problem still lingers.
Message 3 of 9
Guru
I'll see if mine does the same thing...
Guest Network is seen on my RBS: Air SSID
AIR Guest Network EnabledAIR Guest Network Enabled
Message 4 of 9
philoouu
Luminary
Same problem here or almost.
I see the guest network with my satellite I can connect to it with my devices (they appear on the attached devices list connected to the satellite) but there is no Internet available. As soon as I remove the wired backhaul cable and connect to the satellite on the guest network, internet is available...
No idea how to fix that !!! And why it seems to work with other people
Message 5 of 9
dcraig
Guide
Message 6 of 9
Guru
Message 7 of 9
dcraig
Guide
Message 8 of 9
Guru
Glad you figured it out.
Enjoy. Smiley Wink
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1976 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
