Reply
ORBI RBR750 - Selective Connectivity Issue for Iphone 12
mugatu913
Tutor
Ive got the ORBI RBR750 and within the last 2 months my iPhone 12 and my wife's iPhone 12 will not connect to the Internet via the main node. All other wireless devices connect to it just fine, and our phones will connect to the satellites just fine. I can connect to the base via the phone to modify router settings via the app, but I cannot access the Internet. Any suggestions?
iPhone 12 Pro Max iOS 14.8.1 (I'd add an update after i update my iOS)
Security WPA2-Personal
Firmware V4.6.5.14
Thanks in advance
Message 1 of 6
Accepted Solutions
Guru
Re: ORBI RBR750 - Selective Connectivity Issue for Iphone 12
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling WMM and set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 6
All Replies
Guru
Message 2 of 6
mugatu913
Tutor
Thans for your help!
I already had Auto/48 for 2.4/5Ghz and I didn't mess with the channels.
WMM was already enabled, but the 5Ghz CTS was a low number. I set it to 2347 as you recommended and Internet on my iPhone appears to be working now.
You rock. Have a Merry Christmas!
Message 3 of 6
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 4 of 6
mugatu913
Tutor
OK, it looked like it was working but now its not working again. It seems like when the iPhone is connected to the main router, the Internet is still getting throttled to 1Mbps/s. When I connect via a satellite, it will run at 750 Mbps. I think I'm still having the problem.
Message 5 of 6
Guru
Are you sure the phone IS connected to the RBR and not the RBS?
Turn OFF the RBS. Check the speed again with the phone about 10 feet from the RBR.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1596 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
