× You're Invited! Orbi RBK763 Beta Firmware Testers Needed. To participate in testing this trial firmware, please click HERE.
Reply
ORBI WIFI 6
TIJIM
ORBI WIFI 6
I have a ORBI WIFI-6 model G3100 (master and one satellite.  If I want to extend coverage can I just buy one more satellite and add it to the system.  If so is there one you would recommend?
Message 1 of 5
Guru
Re: ORBI WIFI 6
What model is the Orbi RBK3##, 7## or 8##?
G3100 is not a NG model # for Orbi.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 5
Guru
Re: ORBI WIFI 6
G3100 is a verizon router. Are you sure you have an orbi setup?
Of is the G3100 the gateay the orbi is connected to?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 5
TIJIM
Re: ORBI WIFI 6
Apologies.  I did give the model number for the verizon router to which the ORBI router is linked.  The Orbi Router and Satellite are RBR50v2.  Can I just add another Sattelite to extend the coverage.
Message 4 of 5
Guru
Re: ORBI WIFI 6
Yes.
RBS20, RBW30, RBS40v or RBS50 will work. EX7500, 7700 or 8000 will work in a pinch but not integrate like RBS do.
Orbi AX RBS will not work with Orbi AC systems.
Will move this thread to the Orbi AC forum.
Good Luck.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 379 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
