Orbi WiFi 7 RBE973
Reply
Orbi 752- Magneta light
Knine235
Hi,
I have this morning tried to find a solution to clear  the Magneta light which  has suddenly appeared  on both the Router and satellite.
I have rebooted both several times - tried to run the router without satellite , etc to no avail.
Any help with this problem would be much appreciated.
Thanks.
Message 1 of 8
Accepted Solutions
Phyber
Luminary
Re: Orbi 752- Magneta light
The magenta light means it can't connect to the internet. Have you tried to turn off the router, turn off the modem, reboot the modem and then reboot the router? If that doesn't work, Reset the router?
Message 3 of 8
All Replies
Knine235
I should have mentioned I have plugged in my old Netgear 6200 Router and it running well.
Message 2 of 8
Phyber
Luminary
Message 3 of 8
Knine235
Thanks Phyber,
I will try these options.
Message 4 of 8
Guru
What modem/gateway do you have?
Message 5 of 8
Knine235
Thanks Plemans  -  Phybers advice has got me back up and running.
Message 6 of 8
Guru
Enjoy. 📡
Message 7 of 8
Knine235
Great info.
Thanks
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 829 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
