DavidWeller
Oct 07, 2023Aspirant
Orbi 850 or 860 ?
Is the difference in performance that good to justify the difference in price?
Orbi 850 vs Orbi 860
My Broadband at present is up to 1G
Medium size apartment but likely to move to 3 bed semi at some point
So whilst probably get away with just router, I will buy one of the discounted router satellite kits.
1 Reply
10Gb connection rated WAN port on the 860. 2.5Gb WAN port on the 850. Otherwise, all the same. If you only have 1Gb ISP service, the 850 would work well.
