Orbi WiFi 7 RBE973
Reply
Orbi AX 600 RBK 852
kalledog
Orbi AX 600 RBK 852
Hi
I have setup an AX6000 system in Ap mode, many problems, the app from the phone doesn't connect, it says every time it cannot connect to orbi system, but the phone is connected to the wifi.
The devices doesn't switch to the closest satellite or router, this is very bad.
This morning my iphone was not connected to wifi, then it connected but with label unsecure network.
It seems this system is very unstable, I trusted the netgear brand, maybe i did wrong purchase.
Message 1 of 6
Guru
Re: Orbi AX 600 RBK 852
What is the Mfr and model# of the Internet Service Providers modem/ONT and host router the NG router is connected too?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
What iOS is on the iphone? Not seeing any problems with my iphone 12 Max 14.6
Message 2 of 6
kalledog
Hi
the firmware is the latest
Firmware Version
V3.2.18.1_1.4.14
the suqare ft are 2583.338ft
the distance is about 6mt from each other
there are some wifi of Neighbors about 3
iphone 12 pro max 14.4
now for example I'm in the room where the router is , but my iphone is connected to the satellite that is two floors away, it doesn't switch to the nearest device
when I open the app even if I'm connected to the wifi, i get error it cannot connect
Message 3 of 6
Guru
Try some of the suggestions.
Also it's up to devices to pick and choose where they connect too, not Orbi.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
You might update iOS on the 12Max. I see there is 14.7 available...I haven't loaded this yet. I'm on 14.6.
Message 4 of 6
kalledog
I can change CTS
but disabling
Armor, and Set 20/40Mhz Coexistence to 40Mhz only, is not possible I can only enable or disable without specifying 40mhz or is it default when disabled?
thanks
Message 5 of 6
Guru
Remove the check mark from the 20/40 box sets 40Mhz only...
If you have Armor enabled, it should be disabled thru the Orbi app...Then power OFF the RBR for 30 seconds then back ON after it's disabled.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 481 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
