Orbi WiFi 7 RBE973
Reply
Orbi AX AP mode
Retired_Member
Not applicable
Orbi AX AP mode
Hi,
I’ve set my Orbi RBK852 system in AP mode and now video streaming works fine; however all the devices appear to be connected to the main router, despite the satellite is fully working and connected to the router.
Is it possible that the app displays them as all connected to the router even if they’re connected to the satellite or are they actually avoiding the Satellite?
Message 1 of 4
Guru
Re: Orbi AX AP mode
What does the app say for devices connected to the SAT? Nothing or some?
What version of app are you using?
Mine posts devcies that are connected to my SAT. I don't see the same on the router.
Message 2 of 4
Retired_Member
Not applicable
Re: Orbi AX AP mode
It appears as all of them are connected to the router. The sat list is empty
Message 3 of 4
Guru
Re: Orbi AX AP mode
What is the distance between the RBR and RBS? 30 feet is beginning distance.
What happens when you turn down the RBR power on each radio. Say 50% to start. Under Advanced Tab/Advanced Settings/Wireless Settings
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1089 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
