Orbi WiFi 7 RBE973
Reply
Orbi AX RBR852/853, is there a way to separate 2.4Ghz with 5Ghz ssid?
ironmathyu5
Follower
The old trick via telnet not work with new model and firmware. I cant even turn off 2.4Ghz band (which is available with Orbi AC models) , so I can use another router to provide legacy 2.4Ghz service.
This is because the wifi signal makes my kid computer frequently switch between 2.4Ghz and 5Ghz, and he cant play game with it..
I tried lower the power of 2.4Ghz to 25%, but it does not help too much..
Message 1 of 2
Guru
Re: Orbi AX RBR852/853, is there a way to separate 2.4Ghz with 5Ghz ssid?
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 667 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
