Orbi WiFi 7 RBE973
Reply
Orbi AX4200 (RBK753) Wifi calling not working and voice calling freezing
Rafa10
Setup is completed, WIFI Calling isnt working (call failed) and any voice calls (facetime, whatsapp, teams, skype) freeze every few seconds.
Tried to disable SIP LAG, didnt work
firmware is latest (V3.2.18.1_1.4.14)
signal is really good
any ideas whats causing it and how to fix?
thanks
Message 1 of 4
Guru
Re: Orbi AX4200 (RBK753) Wifi calling not working and voice calling freezing
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try setting Set 20/40Mhz Coexistence to 40Mhz only and CTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Message 2 of 4
Rafa10
Hi,
I've tried to configure the advanced tab as you described (image attached), still the same 😞
Size of the house is 400sq of 3 floors, each router on different floor, all connected with RJ45
Internet router is the ISP's default router (HOTBOX 4, which belongs to a company called Hot in Israel)
Thanks
Message 3 of 4
Guru
If the ISP modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 909 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
