Orbi WiFi 7 RBE973
Reply
Orbi Guest WiFi
HMacD
Follower
Orbi Guest WiFi
Orbi RBR850
Firmware: V4.6.8.2
Guest wifi in iPad app shows guest network on and working. Can not see the wifi guest network on any devices. What's up?
Message 1 of 3
Guru
Re: Orbi Guest WiFi
Is GN enabled on the RBR?
Message 2 of 3
CrimpOn
Guru
Re: Orbi Guest WiFi
Would it be convenient to post a screen shot of the iPad app Guest Network page?
As @FURRYe38 mentions, there are several traditional steps commonly taken when electronic devices misbehave, including:
  • Turn it off and back on again.
  • Verify that the web browser administration matches the app. (i.e. they both show Guest network enabled.)
  • Update to the most recent firmware. (because that is one of the first questions people ask.)
  • If all else fails, do a Factory Reset.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 692 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
