- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK752 Public IP Connection Issues with Grandstream UCM6202
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi 6 (RBK752) WiFi Mesh System in my home network. Recently I purchased a Grandstream UCM6202 IP PBX. I have been able to configure the device properly to work within my network without any issues. I am trying to confirgure the system in order to connect my devices outside my network (remote IP phones and Wave Lite smartphone application). I am trying to configure the Public IP on the UCM and the port forwarding on the Orbi 6 WiFi platforms, but am not able to reach my external devices. Do you have any recommendations of how I should configure the Orbi in order to reach external devices on the Grandstream UCM ecosystem?
Note: I would like to note that I have a similar system at the office that works as described and am trying to get my home system to do the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK752 Public IP Connection Issues with Grandstream UCM6202
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi Router Firmware Version: V4.6.5.14_2.0.54
Internet Provider Modem: Arris TG2482A
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #1 first, if not, #2...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Internet Service Provider modem is acting only as a modem. My ISP locks the modem so their clients cannot change the configuration.
As I mentioned in my original message, this is a similar setup I am currently using at the office. I am using the same modem but at the office I have a Microtik router. I have tried to configure the Port Forwarding to the UCM IP PBX network IP, but it does not seem to connect my external devices.
I´ve contacted Grandstream and they recommend I contact Netgear.
Please confirm Orbi has experience connecting the Grandstream UCM IP PBX to the public IP so my softphone and external extersion work. My experience with Orbi up to this point has been seemless. I hope you are able to help me with this last step with connecting my IP PBX.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Confirm that the modem is in modem only mode by let us know if you see a ##.##.###.### address on the RBRs Advanced Tab/Internet section page or a private IP address of 10 or maybe a 192 or 172 address here.
Did you disable uPnP before setting up any Port Forwarding configurations and set a IP address reservation for this one devices on the RBR?
Disable any PF configurations and try putting the devices IP address into the RBRs DMZ and test.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
