Orbi WiFi 7 RBE973
Reply
Orbi RBK753 connection through switch
Ff25m2
Follower
I am looking to set up my orbi and connect satellite through a switch. I'm confused about IEEE. I'm thinking of purchasing GS316P for use. I need a switch as I will be adding security cameras using POE at a later time.
Message 1 of 3
Guru
Re: Orbi RBK753 connection through switch
I believe that model switch should work with Orbi, though I don't have that model. Ones I do have that I know that do work:
NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy... 📡 ‌‌🛰
Message 2 of 3
CrimpOn
Guru
@Ff25m2 wrote:
I am looking to set up my Orbi and connect satellite through a switch. I'm confused about IEEE. I'm thinking of purchasing GS316P for use. I need a switch as I will be adding security cameras using POE at a later time.
The key is that Orbi satellites must appear to be connected to the LAN ports of the Orbi router.  There have been any number of posts describing how a switch is located at a central wiring hub with the Orbi router and satellites in different locations with only a single Ethernet cable installed to each location.  This leads to disappointment.
If the switch is connected directly to one of the Orbi LAN ports and devices (satellites, cameras, etc.) are connected to the switch, that should work fine.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 147 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
