- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK753S issue with Desktop only
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an odd issue. I upgraded to the Orbi RBK753S sold at Costco. Setup was easy and everything is working except for one item. I have a desktop with an Asus Wireless PCI-E Adapter. For some reason this PC will connect, but it's very slow. I had an Eero before and had fast performance.
I've deleted the SSID and re-logged in, I've changed the DNS, I've also tried disabling the 20/40mhz coexistence and uPNP. I don't know what else to do. I'm running the latest drivers on the PC and the latest firmware on the Orbi.
Does anyone have any other ideas?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK753S issue with Desktop only
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the connection rate that the asus adapter is connecting at with the Orbi wifi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It says 650Mbps. However when it does connect I haven't gotten anywhere above 30Mbps on a speed test. I have 500 Mbps service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you disable AX mode?
Ensure the adapter drivers are up to date.
Sounds like this adapter maybe having problems with Orbi wifi. If this is the only device thats having problems and others don't, I would look more into this adapter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you/have you checked for updated drivers for that adapter?
