Orbi WiFi 7 RBE973
Reply
Orbi RBK852 - Unable to connect Big Ass Fans - Haiku series
AwkAndy
WiFi1.jpgWiFi2.JPGI've just switched from an Orbi RBR50 to an Orbi RBK852 to extend the reach of our mesh network.  I had no problems connecting our Big Ass Haiku fans to the Orbi RBR50 but I'm unable to connect them to the Orbi RBK852.  When I try and connect them using the Haiku app, the network fails to even appear as an option.  I get a message from the app saying that the network must be secured with WPA2 (which it is) and must be compatible with 802.11b (which I think it is).  I've attached my current WiFi settings.  Does anyone have any idea how I can get the fans to connect to the network?
Message 1 of 12
Accepted Solutions
Guru
Re: Orbi RBK852 - Unable to connect Big Ass Fans - Haiku series
Try CTS avalues to 2347 under Advanced Tab/Advanced Settings/Wireless Settings and see.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 12
All Replies
Guru
Use the same SSID name that you used on the older Orbi system on the new system.
Try disabling AX mode on 2.4Ghz.
Contact the devices mfr for additional help and support regarding there product.
Message 2 of 12
AwkAndy
Thanks for the advice.  I have used the same SSID name and other devices on the network (iPads, Sonos) automatically connected.  I had to reconnect a Ring device but that worked without a problem.  I also tried disabling AX mode on 2.4Ghz but that didn't work.  As for contacting Big Ass Fans (BAF), I tried that too but they came back with a proforma response that was completely useless (thanks for nothing BAF!).  I have a feeling we'll be stuck with using the remote controls for the fans.  Oh well, I suppose it's a first world problem.
Message 3 of 12
Guru
Message 4 of 12
sharmy
Apprentice
Is your network SSID hidden?
In my environment, the Haiku fans only connected when the network SSID is being broadcast.
Sharmy
Sharmy
Message 5 of 12
AwkAndy
Thanks for asking but no, it's not hidden.
Message 6 of 12
AwkAndy
That did the trick.  Thanks!
Message 7 of 12
Guru
Orbi AX SSID by default is always broadcast and can not be hidden.
So did you get these devices working?
Message 8 of 12
AwkAndy
I did.  Thanks for your help!
Message 9 of 12
Guru
So what did you do to get them working?
Message 10 of 12
AwkAndy
My apologies for not being clearer.  After some experimentation, I've discovered that I can get the fans to connect if I disable AX mode on 2.4Ghz AND set the CTS value for 2.4Ghz to 2347.  Either one by itself won't work.  And it's a real pain because if you change either of those settings after you've managed to reconnect the fans, you have to go through the whole process again in order to connect the fans again.  So once you've changed those settings, don't change them again!
Message 11 of 12
Guru
Ok, thanks for the details. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1810 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
