× You're Invited! Orbi RBK763 Beta Firmware Testers Needed. To participate in testing this trial firmware, please click HERE.
Reply
Orbi RBR 750 issues with Netgear AC1750 cable modem
Gmurakami
Tutor
i recently switched out Spectrum modem with Netgear AC 1750 and have Orbi connected as older cement brick house. Now Orbi speed test won't work and Netgear keeps telling me firmware needs to be upgraded, but I can't access router login site. Considering all devices are netgear I cannot figure out why not working. Considering returning cable modem for Arris modem. Please help with any advice.
Thanks in advance for any help
Message 1 of 12
Accepted Solutions
Guru
Re: Orbi RBR 750 issues with Netgear AC1750 cable modem
Enjoy. Please mark your thread and solved so others will know. Enjoy. Smiley Wink
Happy New Year.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 12 of 12
All Replies
Guru
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 12
Mstrbig
Master
Why do you want to just eliminate the Netgear AC 1750 router all together and just connect the Orbi router to the Spectrum modem, and set the Orbi router in router mode?
Or are you referring to a different Netgear router?
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 3 of 12
Gmurakami
Tutor
To clarify, I replaced Spectrum modem with the Netgear  cable modem. The Orbi router is connected to the Netgear modem.  The Spectrum modem was slow plus I wanted to get away from monthly fees. My house is older and made of cement brick. I need the Orbi router and satellies to extend the coverage
Message 4 of 12
Guru
I think he's referencing the NG cable modem which is probably a C series gatway router modem already. So if this is the case, then they just need to configure the modem for modem only mode. Which would be the first step in solving problems.
Message 5 of 12
Guru
Need to bridge or set modem only mode on the NG cable modem if this is a modem with built in router and wifi.
What C series model is the NG modem?
Message 6 of 12
Mstrbig
Master
Then you gave the wrong model of the netgear, as your first post referred to a specific model AC-1750
AC1750 WiFi Router (netgear.com)
Message 7 of 12
Guru
Or this:
https://www.netgear.com/home/wifi/modem-routers/c6300
Message 8 of 12
Gmurakami
Tutor
C6300v2 is tne modem router. I so appreciate everyone trying to help
Message 9 of 12
Guru
Go into the modems configuration and under Advanced tab/Advanced settings should be Mode or Router mode? Options maybe Yes or No. Select No and apply the setting. This will change the configuration of the modem to Modem only mode. When this happens I would power OFF the RBR for 30 seconds then power back ON. RBR should connect and show GOOD under Internet status on the RBRs web page.
Message 10 of 12
Gmurakami
Tutor
@FURRYe38 your advice was awesome! I did what you recommended and so far so good. Your instructions were easy to follow and I'm hoping fix works. Not the most tech saavy so everyone's advice and support was helpful.
Thanks for the help and hope everyone has a safe New Years!  Gail
Message 11 of 12
Guru
Happy New Year.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1004 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
