Orbi WiFi 7 RBE973
Reply
Orbi RBR/RBS 850 - Firmware upgrade sequencing
veranah
Follower
Hi All,
Are RBR/S850 firmware upgrades cumulative or serial from oldest to newest?
My concern has been raised by a cautionary advisory note that states that you cannot rollback from an upgrade.
Regards
Veranah
Message 1 of 2
Guru
Re: Orbi RBR/RBS 850 - Firmware upgrade sequencing
One of the firmwares, they don't recommend rolling back from because it can potentially brick your device.
but usually you can rollback without concern.
They're cumulative and should contain the prior version's fixes as well as the current releases.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 294 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
