Orbi WiFi 7 RBE973
Reply
Orbi RBR750 Problem
Fractious
Follower
Orbi RBR750 Problem
Hi All,
I have an Orbi RBR750 issue.  Both the router and satellite are firmware v4.6.9.11_2.3.5 and are configured to backhaul traffic through a wired connection.
My issue is that recently the guest network has begun advertising even though its disabled.  I reboot the router and satellite and temporarily goes away, and then at some point within a few days it comes back.
Any ideas?
Message 1 of 2
Guru
Re: Orbi RBR750 Problem
Has a factory reset and setup from scratch been performed since last update?
Try enabling Guest Network, Set a new name for the network. Let the system apply the change. Then after the system is back, go back on disable GN...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 253 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
