Orbi WiFi 7 RBE973
Reply
Orbi RBR750 Takes Forever to Load Admin Screen
doughughes2011
I am having an issue where I cannot load the admin screen with my Orbi RBR750.  First it takes forever to load anything, if it does at all.  And if it does load, it is a mix of text hyperlinks and some icons like below.  But for the most part if it does load properly it takes a very long tome to do anything.  Any help here?
Firmware Version V4.6.3.16_2.0.51
Heres the problemHeres the problem
Message 1 of 8
Guru
Re: Orbi RBR750 Takes Forever to Load Admin Screen
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
Message 2 of 8
CrimpOn
Guru
Is this a combination cable modem/Orbi?  i.e. the CBR750
https://www.netgear.com/images/datasheet/orbi/CBR750.pdf
Has the unit been configured already, or is this the initial setup?
Message 3 of 8
doughughes2011
This is not a combination modem/router and this has already been configured.  Been using it for 6 months or so.
Message 4 of 8
CrimpOn
Guru
This is very strange.  I was not aware that the RBR750 main menu would include "Cable Connection" as a menu item.
My Orbi router takes about 5 seconds for the web Home Page to appear.
Message 5 of 8
doughughes2011
My old Orbi was like that but this one takes 20 to 30 seconds to get this far.
Message 6 of 8
CrimpOn
Guru
You have probably tried Cure #1 (to any technology problem), turn it off and back on again.
Clear the browser cache, then connect to the orbi.
Cure #2 is a Factory Reset, which most of us imagine is like the world's longest enema.  Those lucky souls who (literally) did nothing to set up their Orbi besides changing the WiFi name and password can do this in under 15 minutes.  In my case, I have customized almost every possible setting: DNS servers, DHCP ranges, assigned IP's to devices, created custom devices names and types, setup DDNS, enabled OpenVPN, etc. etc.  I do a Factory Reset in two stages:
Stage 1: Save a copy of the configuration. Get out paperclip and do the Factory Reset.  Connect to the Orbi and begin configuration.  Do not change the WiFi SSID. When I get to the place where there is a choice of "continue setup or load a previously saved configuration", I load that saved config file.  After this, the Orbi reboots, which changes the SSID, and all my devices begin to connect as I wanted them to.
(Do my Lucky Dance)  Is the problem solved.  YAY
Stage 2.  If that did not resolve the problem, then do a Factory Reset and type in everything from scratch (after making screen shots of every setup page).  This takes over two hours. and the family is screaming the entire time.
Message 7 of 8
doughughes2011
Ok, I'll try to go thorugh this process
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1744 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
