mjefmjef
Sep 01, 2024Follower
Orbi RBR750 solid white light, no internet.
Hi, suddenly lost connection and it’s an expensive decoration piece!
Updated to latest firmware. Factory reset several times. Sercomm fibre router settings checked for any device restrictions, and factory reset. I have never manually setup and changed internet provider a month ago without problems, just plugged into new router. All Orbi settings are Auto.
it has solid white display -and connecting to WiFi states no internet connection.
Sometimes I can access through IP address sometimes only through Orbilogin.com ?? when the only option is manual setup, and I have no clue!
App setup obviously says No Device Found although broadcasting WiFi address…..
1 Reply
How did you update FW?
What version of FW did you update too?
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
