Orbi WiFi 7 RBE973
Reply
Orbi RBR840 stopped connecting to internet
ckon9
Follower
We have Cox as our ISP. We have started having internet issues over the past month. Our initial setup was cox compatible personal modem and my Orbi RBR840 mesh system. I had never had any issues with this setup before.
1st issue: our internet went out. After many days I was told our modem was “old”. Even though the specifications were better than what the other options were and it had be working just fine. So I bought a new modem that was on their list from Walmart.
This worked for 24 hrs then stopped working.
Another few days passed bc I thought out outside cable line had be cut due to landscape work.
The ISP came out and everything was fine with the wire.
For there I got a modem directly from cox and connected it to my Orbi… still no internet connection.
I then just went and got the Cox Panoramic Gateway and used it as the modem and router. It works just fine. But I really am missing the coverage that the Orbi mesh provided to our property.
So I tried putting the Cox panoramic gateway into bridge mode and using the Orbi. Still no internet! I even did a factory reset of the Orbi. https://www.reddit.com/r/orbi/comments/17kb0ir/orbi_rbr840_stopped_connecting_to_internet/?utm_sourc...
Any help?!?
Message 1 of 2
Guru
Re: Orbi RBR840 stopped connecting to internet
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Factory reset and setup from scratch using the following process: I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...or #3
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 634 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
