Orbi WiFi 7 RBE973
Reply
Orbi RBR850 Firmware Update
rdlangy1
HI There,
My Orbi App has said for about 8 months that there is no Firmware update to be applied to the router.
Currently it is on Firmware V4.6.3.16
Yet when I search on the Orbi website it mentions about Firmware V4.6.9.11?
Any ideas why my Orbi App wont find the latest firmware to update to?
Ryan
Message 1 of 7
Accepted Solutions
Guru
Re: Orbi RBR850 Firmware Update
Could just be that version has an issue with it. You can always upgrade manually.
I'd recommend upgrading the satellites first and then the router.
Message 2 of 7
All Replies
Guru
Message 2 of 7
Guru
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-4...
@rdlangy1 wrote:
HI There,
Ryan
Message 3 of 7
rdlangy1
Thanks for the info - so are you saying I should update the satellite I have first - manually, then update the router manually, then power both off, and reboot them and all should be good?
Cheers
Ryan
Message 4 of 7
Guru
Correct.
Message 5 of 7
rdlangy1
Brill - many thanks..
Both Satellite and Router updated to V4.6.9.11
Ryan
Message 6 of 7
Guru
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1978 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
