Orbi WiFi 7 RBE973
Reply
Orbi RBRE 960 shows out of sync with satellite, even though i have devices connected to satellite
sfgtsfn
could not get sync to work, however I did get blue light and devices are connecting to satellite.  just shows OOS and everytime I try to resync is says attempt failed.  both devices have same firmware, been reset and are only 20ft away.  is this just a software issues or something i should be concerned with?
Message 1 of 6
Guru
Re: Orbi RBRE 960 shows out of sync with satellite, even though i have devices connected to satellit
What browser are you using?
How are you resetting the system? Are you resetting and setting up from scratch both on the RBS and RBR?
Message 2 of 6
sfgtsfn
chrome, v6.3.7.10, I have reset both and started from scratch.  xfinity internet CGM4981COM is modem
Message 3 of 6
Guru
How are you setting up the system after a FR? Web browser and setup wizard, adding RBS using the RBRs Add Satellite option or Orbi app?
Do you see a Generation Backhaul Password button under Advanced tab/Advanced/Wireless settings on the RBRs web page?
Message 4 of 6
sfgtsfn
I have set it up via router interface and the Orbi app.  I do have a Generate button
Message 5 of 6
Guru
Might FR the RBS then power them OFF. Then select the Generate button. Power ON one RBS one at a time and sync the RBS using the sync button on the RBS and RBR or Add Satellite wizard...
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 679 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
