Orbi WiFi 7 RBE973
Reply
Orbi RBS353 and WiFi 6
Wizzard370
Tutor
I have the Orbi RBS353 setup, which I understand, is a WiFi 6 mesh. I cannot see any reference to WiFi 6 in the WiFi setup section of the router. How do I enable this please?
WiFi Analyser does not pick up WiFi 6 either.
Message 1 of 6
Accepted Solutions
Guru
Re: Orbi RBS353 and WiFi 6
Wifi 6 isn't 6ghz. wifi 6E is.
Wifi 6 just incluced 2.4ghz/5ghz.
when you go to the 6E you get the 6ghz.
The only mesh from orbi right now with 6ghz is the RBKE963
Message 4 of 6
All Replies
Guru
What do you expecd to see?
Wifi 6 is wireless AX and will show up as increased "up to ****mbps" in the settings. You won't see a "wifi 6" option in the router or your devices.
Message 2 of 6
Wizzard370
Tutor
The Wifi Analyser app on my Phone shows 2.4, 5Ghz Channel graphs but the 6Ghz does not show anything.
Message 3 of 6
Guru
Message 4 of 6
Guru
WiFi6 = AX mode on 2.4 and 5Ghz only. WiFi6E = AX mode on 6Ghz only.
The 350 series does not support 6Ghz.
Message 5 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 568 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
