Orbi WiFi 7 RBE973
Reply
Orbi Satellite disconnets when streaming video
Bordigles
Tutor
I have an RBR350 with four RBS350 satellites. My LG TV is connected by RJ45 to one of these Satellites which in turn has a wired connection to the Router via a switch. When streaming videos from my Synology NAS or from BBC iPlayer, the RBS350 randomly drops out of the network and resets. This happens with both 1080p and 720p videos. I have swapped out the Satellite but the problem persists. Last night it dropped out three times while trying to watch a 20 minute program. It has been happening occasionally over the last six months, but recently it is getting much worse.
It has firmware V4.4.1.29.
Is there a log file anywhere on the system that I can download to see what is causing the dropout?
Help please, it is driving me crackers.
Message 1 of 8
Accepted Solutions
Guru
Re: Orbi Satellite disconnets when streaming video
Have you tried changing what channel you're using for the 2.4ghz and 5ghz?
the 350 series is only dual band so is a bit more sensitive to interference/high bandwidth than the tribands.
Message 4 of 8
All Replies
Guru
What happens if for test, you swap out the satellite with another switch so it goes router----switch----switch---tv.
Message 2 of 8
Bordigles
Tutor
Thanks for your reply
Sorry, I have given the wrong config.
The satellite is not connected to the router by copper, only wireless. See attached image map
Message 3 of 8
Guru
Message 4 of 8
Bordigles
Tutor
I'll try that thanks. It was set to auto, I'll try one of the higher DFS channels, they look pretty clear in my location.
Andy
Message 5 of 8
Guru
DFS tends to work pretty well unless you have radar in the area. Then its pretty sketchy.
If it doesn't help, try the higher non-dfs channels.
Message 6 of 8
Bordigles
Tutor
It looks like this has fixed it. Many thanks for your help.
Andy
Message 7 of 8
Guru
Glad to hear it!
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 680 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
