- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Showing Wireless Devices as Wired in Attached Devices List
- Mark as New
- Bookmark
- Subscribe
- Permalink
So if the Satellite backhaul is wired, all the devices connected to it show up as wired in the devices list - no indication if they are 2.4Ghz or 5Ghz. Fairly useless information. I'd use the wireless backhaul, but that shows as "poor", so I figure wired is better for performance - just bad for management.
This problem still exists from older Orbi products - kinda bummed that a $700 router setup retains such a goofy bug.
Solved: Orbi Showing Wireless Devices as Wired in Attached... - NETGEAR Communities
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Showing Wireless Devices as Wired in Attached Devices List
Is the RBS directly wired to the RBR or is there a LAN switch in between?
That link is for the Orbi AC system. Doesn't apply to Orbi AX.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:What Firmware version is currently loaded?
Ha - I reckon you didn't bother to read any of the other link and yes I know it is not about the AX, but it's exactly the same conditions and discussion where they went round and round about firmware versions and switches, etc. And I'm guessing you have never tried the wired backhaul on any Orbi product including the AX or it would be fairly obvious how odd the info is on devices that connect to the satelllite.
Hardware Version | RBR850 |
Firmware Version | V3.2.16.22_1.4.9 |
GUI Language Version | V3.0.0.51_2.1.30.3 |
Operation Mode | Router |
No switch in between and after a few years of this issue, I'm thinking any current product that still has the problem is wishful thinking that the firmware version matters - not until they fix it.
Seriously, if anyone is actually using a wired backhaul and is getting different results, that would be a good story.
I mainly posted this so that anyone else who sees this problem doesn't pull their hair out over it - it's just the way it is. I relocated my satellite last night and now the 5G backhaul is working well - the performance of the entire setup, including LAGing it to the CM1150V cablemodem, is quite good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try updateing to v12:
Both my RBS are wired and just checked again, my iphone 12 max shows at wireless connected to the RBS in the dining room.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That sounds promising - will give a go later.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
