- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi WiFi 6 Slow WiFi/Inconsistent Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi WiFi 6 Slow WiFi/Inconsistent Speed
Customer service is a real disappointment. I'm frankly just going to leave it alone for now - the speed I get is more than enough for what I need; my wanting more is just a psychological thing of wanting everthing to perform "perfectly". But as my wife repeatedly reminds me, perfection is an illusion and its persuit in a router is probably not worth my time!
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's an expensive product, and as advertised I am not getting close to the WiFi speeds. I am getting a fluctuating 200 to 300, maybe 400mbps once in a while. Wonder if there are any other alternative/different name products in the market?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Open floor plan house with 1 main unit upstairs and 1 satellite downstairs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad NG is replacing it. As long as your connection rates are 1300Mpbs or higher, you should see near 900Mpbs. My Mac book pro 2018 seens over 700Mpbs on AC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
In my case, I think I've found that ipv6 was the culprit - when I turned that off I am now getting blazing connections 1200 mpbs to the router, i.e. faster than my internet connection. I don't understand why ipv6 should be the issue, but the problem was not only with speeds: it was kicking my iphone off from even geting proper dhcp addresses when I moved from router to satellite. So something in the ipv6 implementation was blocking proper handshakes it seems. Ipv6 seems optional for now so I'm happy to leave off and by the time we will need it for sure, I'll probably have all new equipment anyway!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is IPv6 supported by your ISP? If no, IPv6 should be disabled.
@Dd852 wrote:In my case, I think I've found that ipv6 was the culprit - when I turned that off I am now getting blazing connections 1200 mpbs to the router, i.e. faster than my internet connection. I don't understand why ipv6 should be the issue, but the problem was not only with speeds: it was kicking my iphone off from even geting proper dhcp addresses when I moved from router to satellite. So something in the ipv6 implementation was blocking proper handshakes it seems. Ipv6 seems optional for now so I'm happy to leave off and by the time we will need it for sure, I'll probably have all new equipment anyway!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, Then please make contact wtih NG support about this. NG needs to know about problems with IPv6 if you have full native ISP support. Not the first time NG has had to fix IPv6 on Orbi.
@Dd852 wrote:
It is certainly supported. And when enabled the router reports correct addresses and connections externally use the ipv6 whenever possible. So it is a bit of a shame to turn off, but the problem with the iphone handshakes was a desk breaker for me
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Blanca_O yes, I have pm'd Blanca. Now that you mention it, I remember having precisely this problem a couple years back with the RBR50 - there was a bad issue passing ipv6 address thgrough the wired backhaul (exactly my situation here too) setting up fatal clashes. On the RBR50 this was resolved with subsequent firmware updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, ya I remember a few problems on Orbi AC.
Hopefully this can be addresssed as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Congrats! I tried for over one month and then they wanted a ton of information on every device on my network. I just gave up, it was too much to make something work. Likely getting an Eero now, I have heard good things.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Luck.
@Akahogan wrote:Congrats! I tried for over one month and then they wanted a ton of information on every device on my network. I just gave up, it was too much to make something work. Likely getting an Eero now, I have heard good things.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
That may have been my issue and I can check too, thanks for the suggestion.
Still waiting on Netgear to ship one out. They send it out via group shipping so I think it will come in next week.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, thanks for letting us know. Well I presume for the most part, IPv4 is still main stream and mostly the norm. Only ISPs that have native IPv6 support for those of you to are on those ISPs have more options. So in part the operation of IPv4 has been the norm for a while and still is. I do agree though that the IPv6 feature on Orbi should work find for those of you who are on ISPs with native IPv6 support.
Enjoy for now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update, got the replacement router from Netgear in the mail.
- Reset AT&T BGW210 Modem/Router Combo
- Went through Installation Steps on Orbi App to get Orbi system setup
- Put AT&T Modem/Router in IP Pass Through Mode (as bridge mode not allowed).
- Enabled Ipv6 on AutoConfig
- Got good speeds in the beginning, see attached, but now again same thing, fluctuatiing speed and I am right next to it and only have a MacBook Pro (2018) connected and iPhone 11 Pro.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good suggestion. I turned off IP Passthrough on the AT&T Model. Turned on the AP in Orbi. Speeds seems to have improved on the MacBook (for now). The iPhone still showing around 250 up/down. I am connected to the Orbi WiFi network I had setup.
Do I need to disable the wifi broadcast from the AT&T Modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Done. But check out the spees on iPhone 11 pro that is capable of getting the WiFi 6 speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree, I have been obsesses with trying to get 600 to 700+ on these newer devices, looks like it won't work.
But, trying to at least get 400 + consistently on all he devices, as it is fluctuating from 100 to 300 right now. In the same spot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
