Orbi WiFi 7 RBE973
Reply
Orbi Wifi 6 Proper Initial Setup Method for guaranteed Ethernet Backhaul?
denizevren
Follower
Apologies for the noob question however given the amount of negative reviews and issues I have read about trying to implement an ethernet backhaul connection between router and sattelite, I feel like I have to get down to OCD level details for a flawless initial setup.
I have just purchased the Netgear Orbi Wifi 6 Mesh System and I'd like to know which out of the box setup method is best for a guaranteed ethernet backhaul connection:
1) - Start with the router pre-connected to the sattelite
- Turn on router first but leave sattelite turned off
- begin setup on router, THEN turn on sattelite and have it connect to router on the already pre-connected cable
2) - Start with the router pre-connected to the sattelite
- Turn on BOTH router and sattelite THEN begin setup procedures
3) - Start with the router NOT pre-connected to the sattelite
- Begin setup procedures on router, THEN turn on sattelite and have it connect to router wirelessly first
- Finally, plug in an ethernet cable between router and sattelite
4) - Start with the router NOT pre-connected to the sattelite
- Connect sattelite to router wirelessly first
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: Orbi Wifi 6 Proper Initial Setup Method for guaranteed Ethernet Backhaul?
I have had best experiences with option run 4.
I tend to setup the RBR first and set it configured for my needs and such. Then connect one RBS at a time wirelessly, then ethernet connect one RBS at a time wired. Make IP address reservations for each RBS on the RBR as well.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 470 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
