Orbi WiFi 7 RBE973
Reply
Orbi Wifi 6 - RBK754 - Setup without App
GaACETech
Guide
Windows 10 environment.
Orbi Wifi 6 router with 3 satellites
Can the Orbi be setup without the app?   Can I go directly to orgilogin.com and access the Orbi setup?  Or is there a default IP address I can use?
I'm a tech and I'm setting this up for someone else.  I'm familiar with Netgear and Nighthawk.
Thanks.
Darryl
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Accepted Solutions
Guru
Re: Orbi Wifi 6 - RBK754 - Setup without App
Yes, use a wired PC and web browser at 192.168.1.1 or orbilogin.net
Message 2 of 3
All Replies
Guru
Message 2 of 3
Guru
it might give you a notice that "netgear recommends the app" for setup.
If you get that page, theres a link at the bottom you can click on to proceed with setup in the browser.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3523 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
