Orbi WiFi 7 RBE973
Reply
Orbi mesh 6e best setting for fast speed and low ping
evry1lovej
Follower
What is the best configuration to get most
Out of the mesh.
Message 1 of 3
Guru
Re: Orbi mesh 6e best setting for fast speed and low ping
The one that works?
Truly its more about testing different setups in your own home. When I first purchased a mesh system I moved it around probably every week and tested the speeds to see what worked best in my own home. This is important to try because things in walls (think hvac/foil lined insulation/etc), furniture, and appliances can all impact how the wifi signal propagates. So testing different locations is going to result in optimizing your performance and wifi coverage.
Message 2 of 3
Guru
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Depending on size of home, you may not need many RBS deployed.
Usually default settings works well.
Ethernet connect the RBS if you have that support in the home.
CAT6 is recommended. CAT6A STP is recommended for 2.5Gb connections.
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 875 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
