Orbi WiFi 7 RBE973
Reply
Orbi router RBR750 not finding home wifi network?
idoc2020
Follower
This may sound a bit confused; however, I have a win 7 desktop that I need to connect to my home wifi network.  I purchased an inexpensive  USB wifi adapter dongle that is dual band 300mbps.  This dongle worked fine on another win 10 machine (so I know it works).  However, when I plug it into the win 7 machine, update the driver and confirm its existence in device manager the machine doesn't give me my home wifi as an option.  It seems to see other networks eg: "Spectrum", "Netgear" and "Other" but it doesn't see the main one that all my devices can see.  My iphones, ipads and even a win 10 desktop upstairs are all seeing "SmithNet" but the win 7 desktop does not.  I've restarted everything, moved around the dongle to different ports, gone into CMD and done an ipconfig dnsflush, reset the winsock, gone into services and checked that wifi lan and dhcp are on etc.  The desktop seems to see two networks that it calls "Other"; however, when I try to put in the SmithNet as the SSID with the relevant password it does not connect.  I've even logged into the ORBI router to confirm the SSID of the home wifi.  Very frustrated and would be grateful for any help.
Message 1 of 2
Guru
Re: Orbi router RBR750 not finding home wifi network?
If other devices are connecting to the Orbi system fine, Something to contact the mfr of this USB adapter about to get support information and help regarding there product.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 194 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
