- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi wifi 6 RBR850 hardwire speeds slow
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently upgraded my home wifi to the newest Orbi wifi 6 imesh, (RBR850) Before i changed out my other router i tested my speeds hardwired and wirless. I am getting 1g thru comcast.. Before i switch routers i was getting 750-900 mbps ( hard wire ) No after upgrading to Orbi im getting 300 mbps on the same computer... At times it will jump up to 700 but before the test is over it goes all the way down to 350 or lower.. Thats one issue im trying to solve.. Another one is, when my iphone 11 is hooked to wireless and i do a speed test ( near the router ) and i get 800-900 mbps, But if i go in the living room where the satellite is i only get 400 or so mbps.. Isnt the point of the satellite to get the max speeds all around the house? Thanks for any help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi wifi 6 RBR850 hardwire speeds slow
Are you sure you are connected to the RBS in the living room with the phone? Besure that when you move near the RBS, turn OFF the iphones wifi for 5 seconds then back on so it will connect to the RBS.
Download and install WiFi Sweet Spots on the iphone to check the connection rate between the iPhone and RBR and RBS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware Version
V3.2.8.5_1.2.3
Modem is a arris Model sb8200
Ill try the sweet spot app and try reconecting the iphone to wifi. Thank you for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are there any switches involved in the wiring>?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm experiencing the exact same thing. Speedtest GigE hardwired are slower than WiFi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm experiencing the same thing. Just posted another thread about it, but following here.
I have Xfinity gigabit and my house is wired for ethernet. Before I installed Orbi Mesh, my iMac Pro in my home office was getting ~930 Mbps down.
After installing Orbi, it was getting only 200-300 Mbps!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
iMac Pro > Ethernet wall port > Xfinity router = 930 Mbps
MacBook Pro > USB to Ethernet adapter > Xfinity router = 930 Mbps
Either computer > Ethernet > Orbi AX > Xfinity modem = 80-200 Mbps
I actually disconnected the Orbi system and went back to Xfinity + xFi pods until I figure this out. The speed of my wired connection for my iMac Pro is more important than faster wireless (and I wasn’t really even getting that with Orbi).
I’m considering Unifi wireless access points as an alternative.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do either of you have anything on your network (hard wired) like Sonos speakers?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't mean to hijack this thread, but yes, I do. I have a wired Sonos setup. This means that I had a Sonos Play:1 plugged in to one of the LAN ports of the Orbi router.
That worked just fine when it was plugged into a switch connected to the Xfinity router. Is there a problem with that with Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have Sonos (and are using Sonosnet -- which you should) be sure that you have one 1 wired entry point into Sonos (e.g. bridge or direct hard wiring to a speaker).
Recommend you disconnect sonos from your router.... and run speed test again and see if your results are different.
Sonos works great with Orbi, as long as you have it connected properly.
I saw an instance yesterday where there were two speakers in a constellation that were connected hard wired and it caused the Orbi speed to be so slow. By disconnecting one of the speakers, all resolved itself and speed picked up to normal... and Sonos worked just fine because you only need ONE speaker connected as an entry point to the network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Sonos Play:1 connected to the router. All other Sonos speakers are in wireless configuration. So, at least in my case, seems like this probably isn't the issue.
Still, I might try disconnecting all Sonos speakers to see if that solves the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend to make sure you are using SONOSNET and not the Wifi on your router. Sonos has the ability of forming its own independant mesh network.... just make sure you pick an unused channel.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I have one Sonos speaker plugged in, which created the SONOSET network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Once you do that, I (and SONOS) recommend you go back in the app and remove any wireless network authentication that may be in there to force your sonos system to stay on SONOSnet and not your WIFI.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes.. doing that prevents your sonos from going back and forth from WIFI to SONOSNET.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So ... are you LAN (ethernet) speeds back in the expected range?
Was it Sonos messing around with the network?
I have no Sonos, but I rely on the ethernet speeds here, and before I upgrade I need to know that they aren't crippled before I commit to RBK853.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My LAN speeds -- even with Sonos, Hue, Nest, 16 x cameras, Pool controller, MyQ Garage doors, Video systems, blue rays, Apple phones, android phones, 7 c samsung TVs, Synology NAS (bonded connection), 7 Alexas, and others (about 90 or so total devices) I am sure I forgot -- are blazing fast.
My experience is that once you get the devices properly set up, they run flawlessly.
I am very confident in the AX6000.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
