Orbi WiFi 7 RBE973
Reply
OrbiRBR50 --> Orbi(AX)RBR850; is it possible to buy RBR850 by itself?
naryaisred
Follower
Hello,
I'm running an RBR50 at home (AC wifi) and it's working fantastic. I'd like to upgrade to the AX version of the Orbi router. Is it possible to buy just the router?
Also, is there a big difference between AC and AX Orbiin anyone's real-world experience?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: OrbiRBR50 --> Orbi(AX)RBR850; is it possible to buy RBR850 by itself?
I haven't seen just the RBR850 sold alone. They currently come in kits, RBK852 and 853. 1 RBS or two RBS.
I would get the kit so you have a full working system.
NG has not made the RBS50 series fully compatible with the RBK850 series system as of yet. No idea when that will happen. They only work wired to the 850 series RBR. And even then some have reported config sync issues with the RBS here and there.
1733Mpbs on orbi AC Backhaul 866Mbps on front haul radios
2400Mbps on back haul on Orbi AX + 2400Mbps for front haul on 5Ghz + 1200Mbps for front haul on 2.4Ghz.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 492 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
