Orbi WiFi 7 RBE973
Reply
OrbiRBR750 does not light up
sigurbg
Follower
This happened to me as well.  The router does not work, boot up.  Unable to connect to it.
Unfortunately, I am just past the 2 year product support by 1 month.
Message 1 of 2
Guru
Re: OrbiRBR750 does not light up
Try swapping Power adapters with one from the RBS to see if this does anything?
Try a 15 second press on the reset button?
Try a 30-30-30 reset on the RBR with it disconnected from the ISP modem?
IF this all fails, the RBR needs replacing.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 169 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
