Orbi WiFi 7 RBE973
Reply
OrbiRBR852 losing wifi frequently
jreid22
I'm at my wits end with the device. It frequently disconnects and reconnects wifi to multiple macbooks in the home. I have the RBR852 with a satelite. Speeds are great when it works. Wired devices have no problem but I have multiple macbooks in the home that connect and disconnect multiple times per day. Firmware is uptodate. for $670 I expect these bugs to be worked out or if I have a bad device then I'll need a replacement. What am I missing here?
Message 1 of 3
jreid22
Re: OrbiRBR852 losing wifi frequently
Model is actually RBK852
Message 2 of 3
Guru
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Set CTS to 2347. Save settings and reboot the router and satellite(s).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 487 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
