- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Parent control
- Mark as New
- Bookmark
- Subscribe
- Permalink
Parent control
But I don’t know How and where can set up parent control if I don’t have circle device
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parent control
Can you set up Access Controls under Advanced Tab/Security/Access Control?
Circle isn't supported on Orbi AX currently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parent control
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parent control
We don't know if or when Circle will be coming to Orbi AX. Something to contact NG support about.
Might post here about this as well:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
If you really need Circle, I would recommend the Orbi AC 50 series system. This supports Armor and Circle.
https://kb.netgear.com/000044718/Which-NETGEAR-routers-support-Circle-Smart-Parental-Controls
Not much else we can do here.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
