- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Puzzling MTU settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have Orbi RBK353 set up.
In Orbi set up, set MTU via WAN setup to 1492 and applied. All seems to be fine.
However if I check in CMD prompt : netsh interface ipv4 show subinterfaces
I get MTU as 1500 for Ethernet and WiFi. Not sure why.
Also, in Orbi, can I set different MTU values for WiFi and Ethernet?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
No. MTU values are not needing any adjustments on the LAN side.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Puzzling MTU settings
MTU on Orbi is for the WAN side only. Check with your ISP to see what MTU value is needed if it's required by the ISP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. So, is there a way to set the WiFi MTU in Orbi (via Command prompt say)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
See page 39 of the user manual: https://www.downloads.netgear.com/files/GDC/RBK352/RBK352_RBK353_UM_EN.pdf
No command prompt needed.
