Orbi WiFi 7 RBE973
Reply
Question to Satellite Connection Type RBR/RBS760
lexlex
Hi everyone.
I'm new here and have a simple question. I've bought a Wifi 6 Mesh System with the RBR760 (Router) and RBS760 (Satellite). Everything works fine but recently I've noticed that in my Orbi App under Details from the RBS760 the connection type shows 5 GHz.
Shouldn't it showing 6 GHz? Cause it's a Wifi 6 Mesh System.
Thanks for you input.
Message 1 of 6
Accepted Solutions
Guru
Re: Question to Satellite Connection Type RBR/RBS760
No. Wifi 6 is 2.4ghz and 5ghz. Wifi 6E is 2.4ghz, 5ghz, 6ghz.
The system you have is a wifi 6 and doesn't have 6ghz.
Message 2 of 6
All Replies
Guru
Message 2 of 6
lexlex
Oh, yeah you're right... Now I regret my investment lol :')
Message 3 of 6
Guru
I wouldn't. there are not many devices that support 6ghz connections so far. And the investment from a 2.4/5ghz router to a 2.4/5/6ghz device is a significant increase. For the most part, its not that beneficial unless you're literally buying the "latest/greatest" in phones, tablets, computers and need the absolute fastest in speeds. Most people really don't as streaming 4k only takes 25-40mbps. Its more of a bragging point currently for most.
Message 4 of 6
lexlex
Yeah I get your point but it's just that I bought a Wifi 6 System to get the 6 GHz Band. Didn't know the 6 GHz Band was only designed with the 6E standard. Now I know better. Anyway, thanks for your quick clarification 👍🏼
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 659 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi 770 Series
