Orbi WiFi 7 RBE973
Reply
RAX 120
corona247
RAX 120
Hello all, newbie here:
Currently have a AX 120 as our house wifi.  Just got orbi premium RBK 752.  Planning on setting the orbi router as an AP using the wired ethernet wall connections I have in the house.
I read that I could maybe setup up WAN aggregation with the orbi and AX120 as that could provide faster connection speeds.  Correct? and if so, can someonw provide an overview of the steps involved to setup.
If aggregation not advisavble, i was just going to follow given instructions per orbi to setup up the orbi's as AP.
Any thoughts, advice, recommendations much appreciated
Message 1 of 2
Guru
Re: RAX 120
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
LAG is not supported in AP mode on the Orbi AX, only in router mode. Mainly meant for the RBR connected to a LAG supporting modem, i.e. CM1100, 1200 or CAX80.
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 261 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
