- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK 753 - LED won't go away
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just upgraded to the RBK 753 (AX4200 w2 satellites).
Weird thing though. ...the LED doesn't go away. It's always on. I know many wanted that but I don't. Any thoughts on how to get rid of it (outside of tape)?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last update? Something to try on the RBR if you haven't.
@IcedCorn wrote:The RBR 750 (Router) has a solid white light on it, . Satellites are fine (no lights).
Orbi mobile app shows everything as fine, I can use wifi and wired fine.
Logging into 192.168.1.1 from a web browser is fine, I get the orbi setup page. The LED doesn't change.
The firmware displayed in the upper right corner of the web browser is:
V3.2.15.25_1.3.15
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK 753 - LED won't go away
Which LED is on, the front LED on the RBR or RBS?
What happens if you log in to the RBRs web page using a PC and web browser?
What firmware version do you have currently loaded?
- Mark as New
- Bookmark
- Subscribe
- Permalink
V3.2.15.25_1.3.15
- Mark as New
- Bookmark
- Subscribe
- Permalink
V3.2.15.25_1.3.15
Strange. Normally the solid white light goes away with a minute after powering up: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean . My RBR850 base and RBS850 satellites lights are all off after the system restarts. I am also running the latest firmware V3.2.15.25_1.3.15.
What does your Orbi admin website says is the uptime of your system? http://orbilogin.com/debug.htm shows my System Uptime is 0 days 12:41:17 (I updated my cable modem yesterday and had to restart the Orbi).
- Mark as New
- Bookmark
- Subscribe
- Permalink
V3.2.15.25_1.3.15
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apparently that was all that needed to be done after the firmware upgrade. Factory reset and re-setup and everything is good. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good to hear. Glad that worked. Be sure to save off a backup configuration to file for safe keeping. Saves time if a reset is needed next time.
Enjoy.
