Orbi WiFi 7 RBE973
Reply
RBK 853 IS OUT!!!!!!
Sevo123
Apprentice
Hi everyone,
Netgear orbi RBK 853 is out and has 2 satalites. Today early morning they had the sole satalite available as a link but it wouldnt open. On amazon it is available on the 15th. I will add some links
https://www.netgear.com/orbi/rbk853.aspx
https://www.amazon.com/dp/B082LZKYFL?tag=price17562-20&ascsubtag=wtbs_5e1524a7e2fd8f3117e06d23&m=ATV...
https://www.bestbuy.com/site/netgear-orbi-ax6000-tri-band-mesh-wifi-system-3-pack-white/6395594.p?sk...
Message 1 of 10
Guru
Re: RBK 853 IS OUT!!!!!!
Yay. Shoul make those of you who wanted a 2nd RBS happy now. Smiley Very Happy
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 10
Sevo123
Apprentice
Sure does! Only problem is that costco doesn’t sell it yet 😞 and the only version they sell is the slower one RBK 842 smh 🤦‍♂️ (Router + Satellite )
Message 3 of 10
DoctorA
Luminary
How much was the single satellite?
ATT GigaPower Fiber-->ONT-->BGW-210 RGW in IP Passthrough mode-->RBR850
Wired Topology RBS50---RBR 850-->RBS850--> RBS50 Ethernet backhaul
Firmware Version V3.2.16.6_1.4.4 for RBS 50 V3.2.16.6_1.4.4Router mode
Message 4 of 10
Rogelio1
Apprentice
I was also looking at the Costco 2 pack and am disappointed they don’t have the rbk853.
What did you mean by slower rbk842? How is the rbk842 different from the rbk852? (I thought it might just be the number reserved for big box stores but didn’t think to see if it was actually inferior)
Any word on individual satellites for sale???
Message 5 of 10
Guru
I think the differences being the max connection rates on the 2.4Ghz radios are slower on the 40 series AX.
You can look at the spec sheets between the 50 and 40 series to see what they are. I think the 5Ghz wireless backhaul speeds are the same thought.
Message 6 of 10
Rogelio1
Apprentice
Ah yes you’re right. Looks like 2.4ghz only goes to 900 megabits/sec versus 1200 on the rbk852.
Are the individual satellites (the 84x or 85x) up for sale anywhere? Only seeing the three pack kit
Message 7 of 10
Guru
Not that i know of.
Message 8 of 10
Rogelio1
Apprentice
Can the RBK85x satellites be added to the RBK84x router?  My concern in buying the costco 2-pack of RBK852 is that I'll only fins RB84x satellites because those are the ubiquitous ones likely for individual sale.
Message 9 of 10
Guru
Probably yes....they would just work at the lower 2.4Ghz connection rate is all. Wireless back haul should be the same.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3577 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
