Orbi WiFi 7 RBE973
Reply
RBK353 — Orbi AX1800 WiFi 6 Dual-band Mesh System 3 pack - additional satellite
Dharmeshk
Follower
Hi There,
I have bought Orbi  RBK353 ( one router + 2 Satellites ) and after installation feels like I will need two more satellites.
Each Satellite is $ 229 each costing $ 460.
Whereas the new pack of RBK353 is available for $ 500.
If I buy a new pack of RBK353, will I be able to use the two satellites for the existing system while keeping the new router unused?
Message 1 of 2
Guru
Re: RBK353 — Orbi AX1800 WiFi 6 Dual-band Mesh System 3 pack - additional satellite
Yes.
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System 📡
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 414 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
