Orbi WiFi 7 RBE973
Reply
RBK750 Access Control does not block device
som1999
I've just installed a new router (RBR750 + RBS750) and turn on the access control with a short list of allowed devices. I tested it by loggin on from a PC that is not on the access list with expectation that it'll be rejected. But no, the PC is added to the "attached device" list with the "Allow" green mark.
I've been using access control for at least 8 years on your old router (R6200) and it has no problem blocking devices that are not on the list. But this is simply doesn't work. Here is my seting.
Model: RBR750
Firmware: V3.2.16.6
Advanced>>Security>>Access Control>>Check on "Turn on access control"
Access Rule: "Block on all new devices from connecting"
Press "Apply" button still doesnt' reflect the change sometime. So I even rebooted the router. Still the same.
If we can't fix this, I may need to return the router.
Som
Message 1 of 3
Guru
Re: RBK750 Access Control does not block device
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Message 2 of 3
som1999
Thank you. I've just posted there. Will try to delete this one.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 738 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
