- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK752 - Awesome but disconnects on facetime a lot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK752 - Awesome but disconnects on facetime a lot
This really sounds like an iPhone issue. Just a brief search turned up a number of hits regarding Facetime wifi vs. lte, such as:
- Mark as New
- Bookmark
- Subscribe
- Permalink
The key seems to be "the instant Facetime is opened, it switches to LTE.. the instant the call drops, it switches back to WiFi"
That sounds like the iPhone, not the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I assume there is no news on this? I’m going to have to try another brand this is causing me such an issue now I’m running out of data on my phone each month as my iPhone is constantly flipping to 4G from the Wi-Fi
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something to try:
@mnichollsuk917 wrote:
Hey
Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Latest being whats on NG download site or what I linked you to?
And you never confirmed if your ISP modem/ONT has a built in router or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the advantage of the firmware you provided, does it fix iPhone disconnection issues? Is it new than the generic latest one provided by netgear as that’s what I’m using at the moment
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was asking if the ISP modem has a built in router. Some modems/ONT do have a built in router. Some do not.
Current released version that was pushed, v14 cause lots of problems for lots of users, probably including you as well. We got a pre-released version from NG in hopes it would bring better stability and experiences for user who were not happy with prior FW versions. So far, seems to be having WAY better experiences for users. Something to try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update the RBS first then the RBR lastly. Follow the upgrading information seen in the post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK were going to pick this back up here as we need to confirm what your ISP Modem (EE Smart Hub) Is doing and what it is.
Is your actual modem/router seen here?
https://www.eehomebroadband.com
We need the model # information of the modem of the sticker please.
So I just got off of a 15 minute facetime call to a Orbi 50 series user while my iPhone 12 Pro Max iOS 15.3 was connected to the RBR850 thats connected to a CAX80 in modem only mode. (Single NAT) Orbi 8 series on v5 FW. Using manual channes 11 and 48. 25% power on the RBR. I have two wifi systems i'm try to keep from creating too much noise. CTS at default of 64. SIP ALG disabled. AX enabled on both frequencies.
I kept checking the phone for signal change or anything odd. Not one event was seen nor did the phone change from wifi to cell during the call. No dropped call during the entire call.
Were thinking that your ISP Modem maybe playing a roll in what your seeing and we need to determine if the modem does have a built in router and if it's active while the RBR is online and also working in router mode. If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes it is the black EE smart hub router for £129.99
When I am home this evening I’ll look at the config page and see if there is a router in / off option
When I had decos attached to this router FaceTime had no issues - it had other issues but FaceTime wasn’t one of them! lol
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I make it to 30 seconds without it reverting to 4G then it won’t drop at all within that specific call
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm pretty sure the EE hubs can't be put inot bridge mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you see anything in regards to IP Pass thru or DMZ by chance? If not, your going to need to put the RBR in to AP mode.
I’ve had a good look around that EE router config page and can’t see an option to disable / enable any router functions
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I put the RBR in AP mode is that all I need to do? Will the RBS still be attached? And is this a possible solution to the problem? I’ll await your instructions before I do anything
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, so this is a double NAT condition that needs to be avoided and is probably the cause of FaceTime immediatly causing the phone to switch from wifi to cell services as the facetime app can't get thru both routers and is probably forcing the phone to cell service to try that connection which probably does work.
So yes, configure the RBR for AP mode. The RBS should follow and get an IP address from the ISP modem. I might turn OFF the RBS before you change to AP mode on the RBR first. Test the RBR in AP mode first to see if the facetime app works with the RBR in AP Mode. If it does, I hope, then turn ON the RBS and it should connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
First FaceTime call was good but I just tried FaceTiming my mum and it disconnected immediately
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was the first FT call with your mom or someone different?
It’s now in AP mode with the RBS unplugged
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So try your Brother again to see if it drops...you said this first call was good and didn't drop?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just tried my friend Graham and it dropped I called him back and it was ok, I then tried 5 times in a row and they all dropped
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, seems like some calls are going thru, then subsequent ones are failing. Wondering if this could be a phone or maybe a ISP/router/ service issue with the Orbi system.
Lets try a full on factory reset on the RBR. Leave the RBS turned OFF. Set up for AP mode again on the RBR.
