- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK752 XBOX Double NAT when connected to satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Recently installed RBK752 with 2 XBOXs in house. One is connected (ethernet) to the RBR, second is connected (ethernet) to one of the satellites. The Xbox connected to the satellite gets the dreaded double NAT error (always when connected via ethernet, occassionally when connected via wireless). Its 100% a problem with the satellite, as the other Xbox connected to the router does not have this issue, nor does the second if I turn off the nearby satellite.
I've seen several posts on this, but no resolution. Is Netgear working on this? Is there a documented fix?
Full setup: Arris TM1602A (Not NAT capable) -> RBR V3.2.16.6 -(wireless)-> RBSatellite -(ethernet)-> Xbox
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK752 XBOX Double NAT when connected to satellite
Does manually changing ports on the Xbox Networking dashboard under Advanced Settings change the status any?
Has a power off for 1 minute then back on been performed since last update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Budshark wrote:Recently installed RBK752 with 2 XBOXs in house. One is connected (ethernet) to the RBR, second is connected (ethernet) to one of the satellites. The Xbox connected to the satellite gets the dreaded double NAT error (always when connected via ethernet, occassionally when connected via wireless). Its 100% a problem with the satellite, as the other Xbox connected to the router does not have this issue, nor does the second if I turn off the nearby satellite.
If you change the RBR750 router to Access Point mode, it will solve the Xbox issue of the Double NAT.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Chris
- Mark as New
- Bookmark
- Subscribe
- Permalink
System has definitely been hard reset with extended power out since last update.
Chris
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Budshark wrote:
I’ll test manually changing the ports but don’t think it will work as the other Xbox connected to the RBR is fine and when this one connects to the RBR it’s fine as well.
Chris
I was mistaken before thinking you had an ISP modem/router which you don't. So this is a very unusual situation since you DO NOT have a double NAT configuration. The only explanation would be a smart router or device setup for DHCP distribution, or there is an issue with the Xbox. Try swapping the Xbox consoles and see if the issue follows the Xbox.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OH, well since you have two xbox consoles, hold the power button in the front of the consoles until they turn OFF.
Go into the RBRs web page and under Advanced Tab, WAN setup, change NAT filter to OPEN. Save the setting, then do a full reboot of the RBR. After the RBR is online and ready, power ON 1 of the consoles, try the one connected to the RBS 1st. Then power ON the other console.
Chris
