- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK752 ethernet ports are slow
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have my RBK752 connected directly to my ONT via ethernet. 1GB FIOS service. I have a netgear switch connected to one of the Orbi's ethernet ports. On the Orbi App, I am hitting close to those numbers (High 900 Mbps up/down). On my laptop about 300 mbps via Wifi. So far, ok.
I then connect my laptop to the netgear switch via ethernet. 50Mbps d/l and barely 20 u/l. Then I connect my laptop DIRECTLY to the orbi's ethernet port. Still 50 Mbps. d/l.
It can't be the ethernet (Cat6) between my ONT and the Orbi because as I've said, I'm getting High 900 Mbps on the app. I have tried several cables, connecting my laptop directly to the Orbi's ethernet port and I get the same 50Mbps.
I have seen many messages in the forums about Orbi ethernet ports being borked and this is beyond frustrating for the price I paid for this. And I'm supposed to pay for additional support??!??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK752 ethernet ports are slow
What is the Mfr and model# of the ethernet switch in the configuration?
What is the connection rate seen on the RBRs Advanced tab/Show Statistics button.
There you should see LAN ports listed. 1000Mpbs should be seen next to each LAN entry.
Whats the WAN port speed seen here as well? Should be 1000Mpbs too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's unlikely, but we should also rule out your laptop's ethernet port + configuration. If you connect your laptop directly to your ONT do you get high speeds? If you still get 50 Mbs then we would look at your laptop vs. the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks...
Netgear GS108 ProSafe Gigabit Switch
I'm assuming you meant the Orbi router - V4.6.5.14_2.0.54
What is the Mfr and model # of the Internet Service Providers modem/ONT the NG router is connected too?
GPON ONT Model FOG421
Not sure where you find this, I've pasted the statistics page below.
1000M/Full on LAN1. LAN2 & 3 show 'Link Down'
1000M/Full
- Mark as New
- Bookmark
- Subscribe
- Permalink
I connected my TV directly to the orbi's LAN ports, and still getting 50Mbps. Wireless is faster.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I took out the network switch. So now everything is on Wifi. The only thing I have hardwired to the lan port is my laptop and I am still getting 50Mbs d/l.
I have already changed all the patch cables to Cat 6.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the connection rate seen with the TV directly connected to the back of the RBR using a ethernet cable?
I would open a support ticket with NG and ask them about this. Seems like the RBR maybe faulty.
